Affichage des résultats 1 à 1 sur 1
Discussion: Code d'erreur
    Membre Avatar de Yanix
    Pointe-Du-Lac
    40
    314
    Code d'erreur
    ce que veulle dire les codes d'erreur
    voila
    #11 Cylinder identification sensor or circuit problem
    #12 Crankshaft sensor or circuit problem
    #13 Intake pressure sensor or circuit problem Cylinder #1
    #25 Intake pressure sensor or circuit problem Cylinder #2
    #14 Intake pressure sensor hose problem .Hose is detached, loose,plugged,pinched,etc on Cylinder #1
    #26 Intake pressure sensor hose problem .Hose is detached, loose,plugged,pinched,etc on Cylinder #2
    #15 Throttle position sensor or circuit problem
    #16 Throttle position sensor is not moving
    #21 Coolant temp sensor or circuit problem
    #22 Intake temp sensor or circuit problem
    #30 Oil pressure sensor or circuit senses low engine oil pressure. ECU turns off main relay and stops engine.
    #33 Open circuit in the primary circuit of the cylinder #1 ignition coil
    #34 Open circuit in the primary circuit of the cylinder #2 ignition coil
    #42 Speed sensor or circuit problem
    #43 ECU unable to monitor system voltage due to an open or short circuit in fuel system circuit
    #44 Internal ECU problem with CO setting or adjustment mode
    #46 System voltage is too high or too low
    #50 ECU internal memory or data problem
    #65 Knock sensor or circuit problem
    #81 Grip warmer open or short circuit
    #83 Thum warmer open or short circuit
    #84 TORS system has been activated
    #85 Short or open circuit in oil pressure switch
    #88 Short or open circuit in reverse indicator switch
  1. code 84
    Par APBY dans le forum Yamaha
    Dernier message: 09/12/2010, 21h34
  2. Code 43
    Par FXLANE dans le forum Yamaha
    Réponses: 14
    Dernier message: 26/01/2009, 08h12
  3. code 84
    Par R-138 dans le forum Yamaha
    Dernier message: 10/02/2008, 18h03
  4. code xp
    Par couleuvre dans le forum SKI-DOO (BRP)
    Dernier message: 14/01/2008, 18h20
  5. Code d'erreur 10-9
    Par MarcT dans le forum SKI-DOO (BRP)
    Réponses: 12
    Dernier message: 13/01/2008, 21h53
